@RebootNZ wrote:
Thanks for that but All i want to do is get the Meraki MX devices to work with over 1/2 the ISP's in Australia.
Not supporting IPOE is causing an issue.  (Want to run the Modem/ Router only in modem mode only via Bridge mode as it is the most stable way.  That way the modem does not crash / Run out of resources.)
Be great to have a workaround or even better have IPOE supported.
It is starting to make me look for other products which is a shame as the Meraki stack is great.
Are you sure you are not overthinking this issue?
In a number of countries I have configured Meraki MX and Z3 appliances to connect to the ISP's termination point via a modem operating in Bridge mode (PPPoA). Meraki devices connect to modems configured this way, without issue. Most of the time I use the non-US version of the Vigor 130 modem (configured as a router in the US).
This allows additional ISP multiplay packages, such as VoIP and premium multicast streaming services, to be activated along with the standard internet connection, over a single physical connection.
Neither the Meraki MX nor Z3 appliances allow an IGMP-Proxy to be configured, which is unfortunate as many non-US premium subscription services require an IGMP-Proxy to be active, as well as IGMP-snooping on the switches.
