Quickest way to update Hub Preference for Meraki Sites?
beta-389-user
Hi All,
I have migration coming in where I would need to introduce 2 Meraki devices as Hubs in existing organization for 50 sites. Which means all 50 sites have existing 1st and 2nd Hub and I will be adding 3rd and 4th Hub. I would really like to perform that change in one go, is it possible at all to do it quickly using template ( using template will bring any new problems?) or can CISCO TAC do it ? I have no API experience so not comfortable with it.
You can indeed use configuration templates to manage multiple networks in your organization. But, there are some limitations when using templates with AutoVPN hubs, it is not possible to configure an MX as a spoke with an exit hub that is part of a template. This means that AutoVPN hubs should not be added to templates at all.
As for CISCO TAC, they will not remove/move devices on behalf of an organization administrator for security reasons.
Managing Multiple Networks with Configuration Templates - Cisco Meraki Documentation
Badr-eddine
Could you try this solution, which might help you:
https://developer.cisco.com/codeexchange/github/repo/baadrdeen/Meraki_vpn_hub_updater
50 sites - I think I would just do this manually via the Dashboard GUI.  If you want to speed it up, just open 50 tabs already open to the correct page, make the changes on all tabs, and then when ready to "commit" just click "save" on each tab.
