Trying to find the quickest way to locate a bandwidth hog in real time going through the MX100. Sometimes I see in Appliance Status -> Uplink I am hitting 125 MB of my 200 MB connection. Checking the total MB for the clients for the past 2 hours is not very helpful because I am seeing file server and database traffic to an from clients over the switches as well.
I just want to see how much is going through the MX in the last few minutes and the break down of who is doing it. I would like to avoid having to download packet captures and counting the bytes if I can. Something I can do right in the interface would be great.
Solved! Go to Solution.
With only an MX there is no quicker way.
I use the packet capture approach with Wireshark.
That stinks. 😞
@JordanNolan wrote:Trying to find the quickest way to locate a bandwidth hog in real time going through the MX100. Sometimes I see in Appliance Status -> Uplink I am hitting 125 MB of my 200 MB connection. Checking the total MB for the clients for the past 2 hours is not very helpful because I am seeing file server and database traffic to an from clients over the switches as well.
If you feel like messing around with the Meraki API, you might find som inspiration here; https://github.com/meraki/automation-scripts/tree/master/topusers
@rhbirkelund would it be possible to provide a guide for a newbie so he can do this?
How about using Netflow?
https://documentation.meraki.com/MX/Monitoring_and_Reporting/NetFlow_Overview
Hi @Weggy ,
When it comes to Netflow I am a newbie if there is any guide that you can provide or refer me to something, please do so. It's highly appreciated.
