Question about how dynamic DNS works on Meraki.
gbrielf
Below is a picture of a failed ping to a dynamic DNS, followed by a successful ping to another dynamic DNS. My question is this: Can this be an ISP DNS problem? Often we get an "unable to resolve lj-0X-xx" alert in our systems.
2 Replies 2
Probably yes, it seems that name is not registered.
GIdenJoe
It has happened before that the name registration takes a while.  Like 30 minutes or so.
Usually the first time a MX network comes up the dynamic-m address is available within a minute.
Always make sure you test different dns servers.
If it still doesn't work, you can try by disabling and re-enabling the feature on the MX status page.  Or by changing the name.
If that doesn't work then you'll need the good ol' support.
