QoS internal traffic MX64
TechTony
I have a NAS and a TV both on my internal network.  Infrastructure is an MX64 and a MS220-8P.  Network is flat.  I'd like to apply some QoS and/or prioritization rules to the streaming traffic between the NAS and the TV.  I've narrowed down the ports and traffic types but am at a loss about building the rules in the MX UI -- let alone whether or not the MX64 is capable of what I want to accomplish.  Expert recommendations?  Thanks!
4 REPLIES 4
MerakiDave
If you wanted to keep the network flat and not place the NAS and TV on a different VLAN you can still set QoS rules for your local LAN, all on VLAN 1 but based on TCP/UDP port numbers under Switch > Configure > Switch Settings.  If traffic will be traversing the MX, you can create those QoS rules under Security Appliance > Configure > Traffic Shaping.  A little more info here https://documentation.meraki.com/MS/Other_Topics/QoS_(Quality_of_Service)
I get a 'page not found' notification when using that link. Got an article ID?
MRCUR
@TechTony Try this, Dave had the last ) missing - https://documentation.meraki.com/MS/Other_Topics/QoS_(Quality_of_Service)
EDIT: Ah ha! The editor is removing the trailing ) for some reason. Add that to the URL and the page will load.
MRCUR | CMNO #12
Uberseehandel
