- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Publish Web Site with hostname
Is it possible publish Web sites of Web Server IIS when they are configured with hostnames?
When I access with URL of hostname (port 80) always open Web site by default of IIS (port 80).
Regards
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
this should work with a portforwarding from public port 80 to internal port 80. Or with a 1:1 NAT as you have it configured.
The hostname is not changed by the MX as it is part of the HTTP header.
What is the problem that you are facing.
Just to mention it, for this config you need split DNS. One DNS that resolves internal requests with the internal IP and one public DNS that resolves the public IP. You cannot use the public IP from internal network if you're behind the same MX as the Webserver.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I am not sure if I understand your question correctly.
If you are trying to publish an internal website with a different port then 80 over the MX to the internet with port 80, you can do it with portforwarding under firewall rules.
So point your external DNS to your MX IP and configure a portforwarding for your MX IP port 80 to your IIS with the specific port.
If you do it on the Meraki MX you can use port 80 only once, meaning you can have only one webserver / TCP port combination published with port 80.
If you have more then oine you need to use a reverse proxy or the like. The Meraki MX is not a reverse proxy.
Am I understanding your problem correctly?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Exactly I have an internal Web Server with several web sites in port 80 with host header. I´ve configured 1:1 NAT and the idea was access via hostname from Internet at the same as from LAN.
Regards
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Oops ... the issue was an error at name of hostname at Binding of web site
When I reviewed from LAN I have detected it. It is working fine
Thanks Markus
