Problems Attempting to Create a VPN Tunnel Within Another
Merkie
We have a branch location with a Meraki MX84 with a VPN tunnel back to our Meraki controller in our data center and all works fine. Recently this branch location purchase a Verizon cell phone extender and they have been trying to get this to work for weeks. We consulted with out internal firewall team regarding the obvious possibility of blocked ports. What they said basically is they saw no traffic to and from the VZ device blocked. However I noticed that the VZ device was trying to build a VPN tunnel in between its self and Verizon. Even if that is allowed with some firewalls it proves to be slow and problematic. Im not a security expert by any means so please share your ideas on this.
SoCalRacer
Setup a DMZ for this device, cell traffic doesn't need to be traversing through your network, it needs direct internet access. Ideally if your ISP supports it have the device connected to their equipment with its own public IP, that way it never has to touch your equipment.
1 REPLY 1
SoCalRacer
