Dear All
Hii.. Iam Sigit from Indonesia
I Have a problem with my device Meraki MX67, My device is already 2 Service (1 MPLS and 1 Internet) and then when user connect to Internet access the speed connection very slowly for the access, If I change to router 1800 Series (Old Device) always smooth running and don't have problem anything Internet or MPLS.
Please Let me know if have case like me
Thanks Advanced
could you provide some more information on how you made the configuration on the mx?
Hii rwiesmann..
For the configuration Only layer 7 Rules = Software & Antivir updates, Web social and Music
Couple of things:
What is your internet speed on mpls and internet?
Did you limit the wan bandwidth in the mx?
Check the duplex setting on the interfaces of mx and conncted routers
MPLS 4Mb Dedicated and Internet up to 2Mbps
Already limit Wan 1 down=2Mbps up=0.5Mbps Wan 2 down=4Mbps up=4Mbps and Fullduplex
Have you configured the MX to use the WAN port that the Internet is connected to as its primary WAN link?
If you are plugging in an Ethernet based Internet circuit is it using auto/auto for its speed and duplex, and if not, have you matched it correctly on the MX WAN interface?
