Pre-connect Message for MFA on Cisco Secure Client
Nightstick
I want to implement MFA with Okta verify.
I want to make a message to ask users to check the MFA soft on their phone for authentication.
I want something like this if possible :  1711iB253C17816BA13E5 (365×337) (cisco.com)
Someone now on to make it on Meraki MX with cisco secure client ?
Best regards
CptnCrnch
Not exactly what you're searching for, but does Okta give something similar like this?
https://guide.duo.com/append-mode
I don't think so, you probably need something in midfield.
Integrating With Cisco ISE you should be able to.
Maybe it will help you.
AnyConnect VPN Okta SAML Configuration - Cisco Meraki Documentation
Configure Cisco Meraki | Okta
I think you are going the wrong way about this.  You should be using SAML.  Users will then see the Okta login page.
@alemabrahao gave some good links.
