Port forwarding
SardarAlam
Port forwarding
 Hello Everyone,
Please assist:
i have added some port in port forwarding but the require task still not working i need port forwarding for 3CX server, So user from outside of network will able to use 3cx server for this i need port forwarding. how can i check my local 3cx server ip that port is opened or not.
6 Replies 6
KarstenI
This is best done on the server itself with the tools of the OS.
And you can put your PC into the 3cx VLAN and do a port-scan.
OVERKILL
Well, first thing: can you connect to the 3CX server from inside the network? I assume that you can and all works as intended?
3CX indicates the following ports are used:
The mandatory ones to be forwarded are, depending on what you are connecting (see notes in the table):
- TCP 5001 or 443
- TCP/UDP 5060
- TCP 5061
- TCP/UPD 5090
- UDP 9000-10999
You can configure these on your MX:
Security & SD-WAN -> Configure -> Firewall -> Forwarding rules
SardarAlam
Port forwarding is configured same like this.
Tobih
What firewall? If your port forwarding is correct but the checker still fails it's usually one of three things:
- Incorrect port forwarding
- SIP ALG is on
- Double NAT or Carrier NAT
SardarAlam
How to disable SIP ALG in MX? I believe  the issue is about SIP ALG.all port showing done but 2 things showing fault.
mxlittletech
Hi @SardarAlam Please can you guide what was the resolution for this issue ?
