Port forwarding rules
How many or is there even a limit on how many port forwarding rules a MX-84 can have?
5 REPLIES 5
Re: Port forwarding rules
65535?
Seriously though, I've never seen a limit anywhere.
There is no limitations.
The limit is your imagination !
Nolan Herring | nolanwifi.com
TwitterLinkedIn
I don't know the answer.
The first limitation would be the number of supported clients.  You can see this in the MX sizing guide.
https://meraki.cisco.com/lib/pdf/meraki_whitepaper_mx_sizing_guide.pdf
I would think you could safely allow for half a dozen NAT's times the number of supported clients.
They may be a physical GUI limit on how many you can type in and still be manageable.
Then there may be a hard limit in the GUI.
Well I've given it a try using the API and I was able to succesfully add about 2200 port forwarding rules to my MX64. Anything above that timed out or gave me a bad gateway error.
