- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Port forwarding not working on MX67
My WAN 1 is down so using WAN 2 to test but that should not affect outcome.
Have configured port forwarding on matching both links, LAN server confirmed is active.
Done a packet capture on both sides, it appears that MX has dropped the SYN/ACK from the server and therefore 3-way handshake not completed.
Removed all firewall rules (actually the rules are not blocking anyway), still the same. Any idea why MX is dropping the SYN/ACK only for port forwarding traffic?
Other outbound traffic is fine.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Found the fix myself. That VLAN if I enable AutoVPN, the port forwarding fails.
Port forwarding works once I turn off AutoVPN. Not exactly sure how the two interacts but I may perhaps configure another VLAN for the AutoVPN.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
It does not make sense. Have you opened a support case?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
No, it doesn't look right to me neither. I'll try to see the best option I have now, given that I am using a workaround for production traffic, falling back to the non-working config for troubleshooting is a bit challenging.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Are you doing a full tunnel for AutoVPN? That would break it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I'm doing split tunnel, that's why I haven't thought of turning it off until I run out of options and give it a try. By the way, I have multiple VLANs, I just need to turn off AutoVPN for that particular VLAN that needs port forwarding to map to. I can still keep the other required VLAN participating AutoVPN.
