Port Forwarding
Steve-Potter
Port Forwarding
 I have a strange config issue here
Internal web server with a few sites accessible via https 443 from specific IP's
name          uplink    protocol   public port   Lan IP            local port    allowed remote IPs
webserver   Both       TCP          443               192.168.1.1    443              a list of 20-30 ip's for access & pingdom etc.
All works fine, website is IP restricted and operates as it should internally and externally from the remote IPs listed.
I now want to add a different port forward for another service, this is using a different port, and works fine internally but not from external, UNLESS the external IP is in the previous port forwards allowed remote IP list
status         Both        TCP          444               192.168.1.1    444              Any
It seems the first entry allowed remote IP's overrule the subsequent allow list, even when configuring a different local IP the Any IP doesn't work, but the previous list does...
I might be missing something here but logically it should work.
PS I know I can add multiple 1:1 NAT's but need to know about this.
Steve
That should work.  It sounds like a bug.
What service is running on port 444? Is HTTPS not correct?
If you have a public IP available, try using 1:1NAT, you can allow several ports for a single IP.
Steve-Potter
Update:
Strangely again, it started working today, and looking at the dashboard, the order of port forwarding rules has changed with the port 444 placed first....hmm
Steve
