Per port vlan settings local override
Michael007
HI, is it possible to locally override per-port vlan config on the MX that is bound to a template? I can see the option on the template but for example if I want to change per-port vlan setting on single MX only not on all devices bound to a template is that possible? I dont have the option locally on the mx bound to a template . Thanks !
2 Replies 2
RaphaelL
Hi , no that option is not possible if the network is bound to a template
@RaphaelL 's statement is correct.
