Hi ,
Just encountered once again a very special behavior on the MX plateform ( running 19.1.5 ).
Testing scenario : I'm capturing IPSec ( VPN tunnel from my computer to a VPN gateway ) trafic on my PC and on my MX which performs L3 routing for my LAN. My goal is to capture all ESP packets and compare the ESP Sequence to quantify the number of ESP packets inbound that are out of order. To my biggest surprise the 2 traces are way different.
As you can see the exact same packet with the same IP ID and the same ESP sequence appears out of order only on the pcap taken on a MX.
Conclusion : The packet capture engine on the MX is way to unpredictable. Packets are routed and forwarded in the correct order , but they will be scrambled in the captures making troubleshoot harder.
Yes. I had a case opened in the past. Yes they said this is expected.
Reason #34591 that I dislike MXs.
