Only MX network (non-MPLS) with SASE(Palo Alto) project
Ayyub
I would be happy If Someone had already migration in practice( Theory no needed):
1) I would like to ask, Did Anyone migrate/remove the MPLS connection in Meraki Area? It is interesting for me, What kind of problems have you already faced when you removed the MPLS connection? I would like to know what happened in practice. The Prisma Access/SASE project(with Palo Alto) is interesting for me.
2) How was the plan for SD-WAN, Security side? Enterprise license was okay or not? What should be noted and planned?
3) LAN:
a)I would like to use 2x MX for high availability(VRRP), What was the reaction if first MX fails(how many seconds)
b) Depends on locations(Big or Small), I would like to use MXs and L2 switchs or MXs, L3 and L2 switch connection.
   Did you have a connection between L2 switches? You can see in Meraki documentation(MX and only L2 direct connection without L3), Between L2 switches connection keep alive 1st MX(if one of MX fails), How was the Spanning tree(rstp) reaction?
What about with L3 connection?(MX>L3>L2), What would be your recommendation for high availability?
Many Thanks in Advance!
5 Replies 5
First, I think you should start reading the documentation.
If you don't feel confident, I suggest hiring a Meraki partner company.
https://documentation.meraki.com/MX/Deployment_Guides/MX_Warm_Spare_-_High_Availability_Pair#Recomme...
Ayyub
as I wrote, Who already did the migration, it is interesting for me, What kind of problems do Other colleagues face? We have a contract with Cisco and Partner Provider and our own big test LAB. As I wrote, Maybe Someone faces with issues/problems in practice. I have much documentation to share with you as well, but I need who migrated nowadays (sometimes theory and reality are not the same):
•MX Failover HA: https://documentation.meraki.com/MX/Networks_and_Routing/Routed_HA_Failover_Behavior
•Meraki MX Warm Spare: https://documentation.meraki.com/MX/Deployment_Guides/MX_Warm_Spare_-_High_Availability_Pair#
•MX datasheet: https://meraki.cisco.com/product-collateral/mx-family-datasheet/?file
•MX85 WAN Port behavior: https://documentation.meraki.com/MX/MX_Overviews_and_Specifications/WAN_behavior_on_MX75%2F%2F85%2F%...
•Meraki SFP: https://documentation.meraki.com/General_Administration/Cross-Platform_Content/SFP_and_Stacking_Acce...
•Meraki License overview: https://documentation.meraki.com/General_Administration/Licensing/Meraki_MX_Security_and_SD-WAN_Lice...
HA: MX Warm Spare - High-Availability Pair - Cisco Meraki
Ayyub
Of course, later I will do everything in the test LAB, But Now, I am planning the runbook, design, and preparation before starting this migration process. I am open to seeing recommendations, suggestions and etc. Many Thanks in advance.
Brash
A few anecdotal comments
1) I've migrated a few sites from existing MPLS connections to DIA SD-WAN.
It made sense for that business and their use cases. It was a relatively seamless experience. The tunnels have very high uptimes and has had a positive end user experience.
2) This depends on the client but for anything of a decent size SME business, I look at Advanced Security or better
3) I don't have any sites running HA in routed mode. I have one site running HA VPN concentrators. Failovers between then appears to be relatively quick but haven't tested in a long while
Ayyub
Many thanks for your comments!
