Hi
I'm new to Cisco Meraki.
I have two HUBs and two spokes using S2S VPN in my same organization name as below.
HUB:A - Spoke:BranchA (Site-A)
- using passthrough mode (HUB:A)
- direct P2P connect with router (via Meraki WAN1 :IP 192.168.10.1/30)
- using routed mode (Spoke:A)
- advertising 192.168.0.0/16 in vpn setting as local network
HUB:B - Spoke:BranchB (Site-B)
- using passthrough mode (HUB:B)
- direct P2P connect with router (via Meraki WAN1 :IP 192.168.100.1/30)
- using routed mode (Spoke:B)
- advertising only its upstream network (192.168.100.0/30) in vpn setting as local network
Our syslog server IP is 192.168.200.254 located at Site-C.
HUB:A is sending logs well to syslog server via its WAN IP: 192.168.10.1 , but HUB:B is not sending logs to syslog server via its WAN IP: 192.168.100.1.
I found it's sending logs to syslogs sever via Meraki dashboard IP: 6.xxx.xxx.xxx. and all the syslog traffic of HUB:B is going to HUB:A which is adverstising 192.168.0.0/16 network.
please help and let me know if my info is not complete.
Note:
- Site-A, Site-B and Site-C are connected via MPLS.
- IP are example.
- Sorry for my draft diagram
