Numbers of WAN ports
Mauricio-Citel
i have a question.  Is there a meraki device that has more than 2 WAN ports?
Accepted Solutions
MRCUR
Re: Numbers of WAN ports
No, the MX line has a max of two WAN ports currently.
MRCUR | CMNO #12
3 REPLIES 3
WadeAlsup
I believe the entire MX line of security appliances either have a second dedicated WAN port or can be configure to use another port for WAN as well.
EDIT: Sorry, I missed the "more than 2"
Found this helpful? Give me some Kudos! (click on the little up-arrow below) and If my reply solved your issue, please mark it as a solution 🙂
MRCUR
MRCUR | CMNO #12
Mauricio-Citel
MRCUR,  thanks for your answer
