- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Non-Meraki IPSec tunnel issue
I'd like some helps to understand more or if there's any limitations between Meraki SDWANs and non-meraki ipsec tunnels.
My conf is below:
1st Meraki Site subnets: 172.17.0.0/16
2nd Meraki site subnets: 192.168.48.0/20
3rd Meraki site subenets: 192.168.10.0/24
4th Annyconnect VPN subnet: 192.168.44.0/25
Non-Meraki site subnets: 192.168.3.0/24
- The 3 meraki is ok with the site-to-site auto-VPN
- I need to configure an ipsec tunnel to allow the non-meraki subnet to reach all meraki networks but actually it just work with the 1st Meraki and Annyconnect subnets (172.17.0.0/16 and 192.168.44.0/25) and doesn't work for the two other sites.
Can anyone please help me to understand what i missed ?
Thank you very much
BR
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
There is no limitation on the number of tunnels, but remember that the Peer not Marki must know the subnet of each Site and an individual tunnel must be created for each site on the Peer side. Do you know how it is configured on the Peer side? What is the vendor on the Peer side?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks for your reply,
All private subnets are already declared in both the Meraki & the non Meraki peer (Ruijie Networks router)
- I can reach the non-meraki peer subnet (192.168.3.0/24) from device connected to the Anyconnect VPN.
- I can reach the non-meraki peer subnet too from the 1st Meraki main subnet (from 172.17.0.0/16) but not from the other subnets within the Meraki peers (2nd and 3rd)
Thanks in advance for your helps
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Make sure each Meraki site makes a non-Meraki tunnel towards the non Meraki network.
As alemabrahao already mentioned, you cannot include SD-WAN remote subnets in a non-Meraki VPN. It can only route client VPN, local subnets and static route subnets.
