Non-Meraki IPSec peer between 2 MXes in the same org
svenus1977
Just browsing
Hello experts,
 Can I establish IPSec peer between 2 MXes within the the same org, rather than going onto Auto VPN?
 I was having issue that Auto VPN breaks the port forwarding config:
 https://community.meraki.com/t5/Security-SD-WAN/Port-forwarding-not-working-on-MX67/m-p/190775
 But eventually, I need to keep the IPSec tunnel going when the other site (currently an old Cisco router, setup as a non-meraki peer between the MX) migrates to the MX.  Since I can't use Auto VPN, I wonder if the non-Meraki IPSec peer works for 2 MXes in the same organization.
  Thanks.
5 Replies 5
Yes you can, but you will lose the benefits of auto VPN.
Just a note, if they are in the same organization both cannot be HUBs.
The more I think about this - probably no.
To configure a non-Meraki VPN you first have to enable AutoVPN.  As soon as two sites have AutoVPN enabled, they will talk to each other via AutoVPN.
So I am going to say no.
svenus1977
Just browsing
Thanks @alemabrahao @PhilipDAth for the replies.
I think I can get this working and would give it a try:
- I have the 2 sites that definitely will be spoke, so should be fine.
- I have multiple VLANs.  I just need one VLAN to be disabled with AutoVPN, but then use non-Meraki IPsec peer to reach the same "disabled AutoVPN VLAN" on the other site.  I have another VLAN that goes back to the AutoVPN that can reach to Hubs.
The reason for this complicated design is due to the another issue I posted on the other thread, which AutoVPN enabled VLAN breaks port forwarding. Even I am using split tunnel, I can never get port forwarding to work.  And the port forwarding requirement is something I cannot ignore.
svenus1977
Just browsing
Replying to myself.  Turning off the VLAN for Auto VPN does not work in my case. As turning off Auto VPN automatically breaks the IPSec tunnel.
I have opened a case to investigate the issues.
