Newbie question on routing
JWvE
Hi, we have two sites linked through AutoVPN.
Site A: 192.168.148.0/24, the MX64 has 192.168.148.254.
Site B: 192.168.71.0/24, the MX64 has 192.168.71.1.
My PC is in site B and has 192.168.71.2.
From my PC in site B I can ping any device in site A.
From any device in site A I can ping the MX64 in site B, but I cannot ping my PC.
From the MX64 in site B however I can ping my PC.
I don't really understand how that is possible. I must be overlooking something, I am very new to Meraki.
The MX64 in site B is configured in NAT mode.
The MX64 in site A is in passthrough mode.
Devices in site A know about the route to the IP subnet in site through a static route on the default gateway in site A.
From a host in site A:
Tracert 192.168.71.1
Tracing route to 192.168.71.1 over a maximum of 30 hops
1 <1 ms <1 ms <1 ms 192.168.148.1
2 <1 ms <1 ms <1 ms 192.168.148.254
3 8 ms 6 ms 6 ms 192.168.71.1
Trace complete.
Tracert 192.168.71.2
Tracing route to 192.168.71.2 over a maximum of 30 hops
3 * * * Request timed out.
4 * * * Request timed out.
I would be very happy if someone could point me in the right direction.
Thank you
Accepted Solutions
Re: Newbie question on routing
It sounds like you might have Windows Firewall enabled, which blocks ping outside of your local subnet.
4 REPLIES 4
Rudi
I think this is the answer to your question - if the MX64 in site B is in NAT mode - you shouldn't be able to ping through it. Since anything on the inside is translated to have a single IP.
Edit: I've never used AutoVPN - the fact that you have one in NAT mode may be completely irrelevant.
JWvE
Yes, I am awfully sorry, this is incredibly silly. I did of course check the Windows firewall. I checked it, however, when I was connected to the office LAN, not after I patched my PC at the MX64. My PC thinks this is a new network and decides to block ICMP as the default setting. I am really sorry to have bothered you, but also very thankful.
No worries. It catches everyone out with its dynamic nature.
