This is an early-stage beta version for the MX 16 release. Due to this, we recommend taking additional caution before upgrading production appliances. Where applicable, MX 15 or MX 14 releases will provide a more stable upgrade alternative.
Legacy products notice
When configured for this version, Z1, MX60, MX60W, MX80, and MX90 devices will run MX 14.55.
Bug fixes
Added support for AnyConnect VPN clients roaming to different public IP addresses.
Updated the AnyConnect VPN service.
Updates to the AnyConnect VPN configuration should now cause less disruption to connected AnyConnect client VPN clients.
Corrected an issue that could result in a device crash when NBAR was in use.
Resolved an issue that resulted in MX appliances incorrectly forwarding traffic across the site-to-site VPN when the following conditions are met: 1) the MX appliances operating in one-armed VPN concentrator mode, 2) site-to-site VPN was enabled, and 3) traffic was received on the WAN interface with a source IP address matching the MX’s WAN interface IP. This situation could arise during an unintended routing loop and will now be dropped by MX appliances.
Fixed a case where the non-Meraki VPN service was not stopped when all non-Meraki VPN peers are removed from the configuration.
Corrected an MX 16 regression that caused MX appliances to be unreachable after failing over to a cellular connection when that connection required an MTU below 1500.
Resolved an MX 16.4 regression that resulted in MX appliances configured to operate in passthrough mode while also configured to operate in warm spare / high availability (HA) mode, using an incorrect MAC address for traffic sourced from the virtual IP address (VIP) of the HA pair.
Known issues
After making some configuration changes on MX84 appliances, a brief period of packet loss may occur. This will affect all MX84 appliances on all MX firmware versions
Some stability-impacting issues present in MX 14 that affect a small population of MX67(C,W) and MX68(W,CW) appliances still exist.
Some stability-impacting issues present in MX 14 that affect a small population of Z3(C) appliances still exist.
Please note that until certification has been obtained, the Z3C will not be supported on Verizon's network.
World-wide device SKUs of the MX67C, MX68CW, and Z3C units cannot be deployed in North America and North America device SKUs of the MX67C, MX68CW, and Z3C units cannot be deployed outside of North America.
When deployed in warm spare / high availability (HA), MX67C and MX68CW do not support using their cellular connectivity to pass client traffic. In this deployment, the cellular connectivity can only be used for device monitoring or network troubleshooting. This is an expected limitation for these platforms.
MX67C, MX68CW, and Z3C units must be connected to the Meraki Dashboard initially to retrieve an update to allow for proper use of the integrated cellular connectivity. This is most likely to be an issue when bringing the units online for the very first time.
On the MX67(C,W) and MX68(W,CW) platforms, when the MX is providing PoE to a connected device, this information will not be reflected on the Meraki Dashboard.
Due to MX 15 regressions, USB cellular connectivity may be less reliable on some modems
Due to an MX 15 regression, the management port on MX84 appliances does not provide access to the local status page
Client traffic will be dropped by MX65(W), MX67(C,W), and MX68(W,CW) appliances if 1) The client is connected to a LAN port with 802.1X authentication enabled and 2) The VLAN ID of the port is configured to 16, 32, 48, 64, 80, 96, 112, 128, 144, 160, 176, 192, 208, 224, or 240.
Significant performance regressions for VPN traffic may be observed on MX84 and MX100 appliances
Group policies do not correctly apply to client devices
Z3(C) appliances that are upgraded to MX 16 versions cannot directly downgrade to MX 14 releases. They must first downgrade to an MX 15 release.
MX IDS security alerts are not detected for Anyconnect VPN traffic
BGP-learned routes may not be properly reflected in the Route Table page on the Meraki Dashboard, despite BGP and packet routing operating correctly.
There is an increased risk of encountering device stability issues on all platforms and across all configurations.
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_140caeb50d2931","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_140caeb50d2931_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_140caeb50d2931_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_140caeb50d2931_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_140caeaefb571d","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
