Hi, if anyone here is able to help me I would appreciate it a lot as I have essentially given up on this after trying for over a week now.
I work in a small business of about 20 people. We currently have 4 VLANs. The main one (VLAN ID = 1), and 3 other subnets (2, 10, 20).
I want to get part of the network hardware on a completely new VLAN (30). I have created this VLAN with the correct uplink port settings according to all of the user guides I have seen but it will not work when I go into my Zyxel switch and set the VLAN ID to 30.
I currently have a laptop plugged into a single port on the laptop and when I set the VLAN ID = 30, I get a broken IP address in command prompt when I type ipconfig = 169.254.190.197, and I also have 'unidentified network'.
When I set the same port to VLAN ID = 20, I get a nice IP of 192.168.20.235, and I have a working network, connect to internet, etc...
If nobody here can help me I think  I will give up as I have tried everything. I will attach images of some of my settings with personal info removed. Thanks.
VLAN Addressing settings: https://gyazo.com/6059958e9e63c1e92d0fbb8bd34e99e4
Zyxel Nebula port config settings: https://gyazo.com/f030b8a519e2ab2a9845855c84a96c16
Zyxel switch IP login VLAN settings: https://gyazo.com/77d7b237432678568966db7239035af8
Thank you.
Lorcan
