I have a new Meraki MX68 and all it does is go to the orange/amber light after cycling through the rainbow colors.
I tried it at work then to have a simpler network, I took it home and tried uplinking it to my Ubiquiti, which is a basic NAT router, so it provides something like 192.168.1.0/24 with DHCP between 192.168.1.100 and .149
I have tried both Internet ports, different cables. Tried holding the reset pin for 10 seconds (it actually restarts before then and I keep holding). I verified if I plug the Internet cable into another device (laptop) that it instantly pulls an IP from DHCP, and the laptop works.
I tried a static IP on the laptop in the same range, which also worked for the laptop. I logged on the web interface and put in the same static IP configuration using DNS 8.8.8.8 and 1.1.1.1 ... no change. I am 100% sure my connection is Direct (not PPPoE) and that I am not using any 802.1q VLAN tags for this.
I tried leaving it overnight too...
Any ideas? I have never run into this problem before to this extent. I have seen behavior like this before, but it resolved on its own in a few hours of sitting.
