Need users to connect automaticaly with MX64 in MULTIPLE SITE
Senan_Rogers
Hello Team,
I have two sites, HQ  and Branch... In HQ  we are using MR33  and in the Branches, we are using MX64W.
I have setup  Same SSID name and Preshared Key password in both locations (HQ, Branch).
the Scenario / Question:-  If the Corporate Users in HQ will be connected to that SSID then the same user move to the Branch location and try to connect to the SSID in the branch which should have the same name and same Preshared key as the HQ SSID , will that user be able to connect automatically without doing any authentication ?
It should be working, but i am a little concern about the way of the authentication as we have AP in HQ  and MX64W  in Branch could be an issue.
can you please advice?
Thank you
Steinbep
If they have the same SSID and same PSK they will connect as expected.
I use this same idea in 60 field sites only I use WPA2-Enterprise instead of a PSK. Works without issue.
1 Reply 1
Steinbep
