NET::ERR_CERT_AUTHORITY_INVALID
Tal
There are some websites that I can't access, such as Facebook or Youtube.
the moment I hit enter I get the following:
Your connection is not private
Attackers might be trying to steal your information from www.youtube.com (for example, passwords, messages, or credit cards). Learn more
using another SSID, not via the Meraki AP, I have no problems at all.
6 Replies 6
CptnCrnch
Sounds like you have Content Filtering enabled. When accessing some kind of ressource you're being redirected to a block page that onviously (in case of HTTPS) can not provide your browser with the corresponding certificate.
bvdijk71
For testing purposes, what happens when you whitelist a client and try the same website(s) again?
Tal
how do I do that?
I didn't find the mene
It is under the Network-wide/Clients menu and shows for clients that can be controlled; wireless if you have MRs and wired if you have MXs on the same network.
Fabrice
I have the same problem.: NET::ERR_CERT_AUTHORITY_INVALID when I try to access for a specified site.
I try whitelist for my pc (verified with my IP)
If I connect my PC direct to the Internet box, there's NO problem.
Could someone help me ?
Fabrice
I resolve my problem.
I have change my DNS configuration.
The problem was with my DNS set to OpenDNS 208.67.222.222 & 208.67.220.220
I have change for Google DNS
