NAT in MX100
Zenit
Just browsing
NAT in MX100
Hi everyone
I am setting up two MX100 for the first time and had some questions about NATs.
When I configure an incoming NAT do I also need to do the ACL, like for example on ASA?
Another question: are outbound NATs configurable?
For example my network 192.168.0.0/24 comes out with IP 82.14.25.55 and my other network 10.255.255.0/24 comes out with IP 82.14.25.56?
Thx in advance for help
Regards
Angelo
KarstenI
When you create a NAT a rule is created allowing "any" access to those port(s).  You can edit that and change it to a specific IP address(es).  It is under Security & Sd-WAN/Firewall.
@Zenitwhen you talk about outbound NAT "my other network 10.255.255.0/24 comes out with IP 82.14.25.56", that is something that unfortunately the MX range does not do, you only have the option of 1:1 NAT as @KarstenI said, this is usually used for say a mail or web server hosted inside your network that you do not want to be on the main public IP address used by the outbound general internet traffic.
