Hi Brecht
Thanks for the answer and sorry for the delay. I still have a question. The way I understand PAT (NAPT) it always consists of a two tuples: one describing local SrcIP/SrcPort and the corresponding global SrcIP/SrcPort, the other one describing local DstIP/DstPort and the corresponding global DstIP/DstPort.
Now for the MX1 this would be something like local IP10.1.1.1/UDP40001 and global IP1.2.3.4/UDP40001 to local 64.62.142.12/UDP9350 and global 64.62.142.12/UDP9350. This in my opinion punches a hole for the connection between the two endpoint IP addresses. When having a second MX2 behind the same ISP firewall the situation would look like that: IP10.1.1.2/UDP40001 and global IP1.2.3.4/UDP40002 to local 64.62.142.12/UDP9350 and global 64.62.142.12/UDP9350. The UDP port for both MXs differs on the outside, but in my opinion only for the communication to 64.62.142.12/UDP9350.
When assuming that an access point tries to set up a connection to MX2 it sends a UDP packet to IP1.2.3.4/UDP40002. Since the public IP address of the access point is not known the packet is dropped at MX2's ISP FW. Now if the MX2 tries to open the communication to the AP: is there a rule for the ISP FW to use the same UDP port number (40002) to the different public IP address of the access point? Or is it just the way most of the NAPT devices work?
Sorry to bother you again but maybe you can help me understand the process more profoundly.
Kind regards
Mat
