Migrate Checkpoint to MX Firewall rules/nat etc
sambo
Is there a tool to allow this migration to happen more smoothly than a full manual process?
Sam
BrandonS
Nothing official, but a small possibility someone has developed a script using the API.  You could look around https://developer.cisco.com/meraki/ to see if there is anything helpful and get some ideas.
An advantage of the Meraki dashboard is that you can do all the configuration ahead of time though.  So doing it manually is a little less painless then working on a live device.
Inderdeep
@sambo : Check this one as well
https://github.com/meraki/automation-scripts
Regards/Inder
www.thenetworkdna.com
Inderdeep
@sambo : Another NAT rules on MX
https://developer.cisco.com/meraki/api/#!get-network-one-to-one-nat-rules
Regards/Inder
DarrenOC
Not that I’ve seen.  I would however take the opportunity to do some housekeeping on your existing rules etc. Perfect opportunity
