Merging two organizations in dashboard
BT1
Hello, We have to merge two organizations into one. Please if someone can provide clarity on below.
1> What needs to keep in mind about device licenses.
2> Will the WAN IP configuration of the devices will be lost when moved
3> How can we make two HUBS not talking to each other when two organizations are merged.
You have to open a support case and request a licence transfer.
5 REPLIES 5
The merge will be a manual process.  I'm not sure about the WAN IP, but there is a pretty good chance this will be lost when moving between orgs.
Hubs always build AutoVPN tunnels to each other.  You can't stop this.  You can create VPN firewall rules to limit communication.
All spokes from both orgs will need unique addressing.
@BT1 If you don't want the hubs from Org A to talk to the hubs in Ord B why are you merging the orgs, I have two orgs and it is very easy to manage them independently.
BT1
Yes, because we are adding VMX as a network and if we dont merge both orgs then we will have to buy two VMX network for each org.
Thanks Philip.
Anything about devices license that needs to be taken care of please?
