Meraki warm spare Configuration
Warm-Spare
I am planing to configure meraki warm spare. I have following doubts
1. Both Meraki devices should be identical ( Hard ware and configuration )
2. Can i use same Public ip in both devices
3. can i use same Lan interface ip in both devices?
2 REPLIES 2
1, yes
2, yes. But the (private) ip address  of the mx WAN port itself has to be unique.  / You can configure  a VIP if you want (3rd address needed)
3, yes, this  will be done automatically when adding the 2nd mx
https://documentation.meraki.com/MX/Deployment_Guides/MX_Warm_Spare_-_High_Availability_Pair
Allow me to clarify this a step further.
Each MX WAN interface in use must have a unique IP address.  This might be a public IP address on a routed subnet (such as a /29) or a private IP behind something else doing NAT.
However you can also have an additional VIP - a shared IP address - that is controlled by one of the MX at a time.  If an MX or something fails the other MX takes over that IP.
