Meraki device communication to cloud Dashboard
knaik99
on which ports ,Meraki devices communicate to cloud dashboard?
means which ports should be opned in firewall to have communication with meraki dashboard from meraki device
1 Reply 1
Brash
Meraki devices use a number of different ports to reach the cloud.
If you login to the dashboard and navigate to Help (top left) -> firewall info, you'll be taken to a page that shows the required IP's and ports for your Meraki devices to connect to.
