We operating meraki device network
and provide client sslvpn via Anyconnect program.
In client sslvpn, Is there any how to IP address fixed setting?
If right, Please share how to set up?
Thank you,
Best Regards.
Solved! Go to solution.
No.
The Anyconnect configuration gives the client an IP from a configured subnet.
You might be able to set a fixed IP address for the client on the clients page but it would require some testing to see whether it would work.
