Meraki and Citrix
kima25
Meraki and Citrix
I am working on a project for a client who deploys the Citrix solution, the workstations are in thin client mode, he has two WAN accesses (MPLS + internet),
My question is, is the Citrix solution compatible or adapted for SDWAN solutions, if yes, will the MX be able to manage the flows correctly without saturating the MPLS link?
Are there any prerequisites or limitations for deploying Meraki SDWAN with the Citrix solution?
Thank you for your help.
1 Reply 1
I'm pretty sure that the answer is not, but why don't you try a POC before?
