Meraki Z4 and iPSK or mPSK
Bubblehead
We were using Meraki Z3's with iPSK with Cisco ISE 3.3 and things worked great.  We're now migrating to the Z4's and I've noticed that the Z4's no longer support iPSK.
Anyone know if Meraki is going to reintroduce iPSK feature back into the Z4 appliance?
Anyone have a workaround?  Our Z4's also have an SSID that uses our ISE server for AAA. Anyway we could piggyback off the same SSID using the 802.1x and PSK at the same time?
2 Replies 2
rhbirkelund
From what I know of, the Z3 can't do iPSK either, so how do you mean that it is no longer supported on Z4?
KarstenI
You can‘t have both 802.1X and PSK on the same SSID. It’s one or the other.
Well, technically it could work. But most vendors prohibit it as clients get confused with that approach.
