Meraki WAN port
SardarAlam
Meraki WAN port
Hi everyone,
How to assign Public IP to WAN port? As one of my mx has Public IP and Same is WAN port IP. I want to configure same setup in my 2nd mx where i have 2 different IPs one is Public Ip other is Private IP,
8 Replies 8
You can get it from the isp dhcp
Or assign static
https://documentation.meraki.com/MX/Other_Topics/Static_IP_Assignment
In case you are talking about a nat isp router, then you should contact the isp, if its possible to get a public ip/ or remove the nat router
SardarAlam
Thanks for your prompt response, Can we configure Client VPN without ISP static IP, If we have a normal connection where IP got from ISP is changing, so our link for Client VPN will be valid or we require to configure vpn with every time IP change?
I think it should work fine if its possible to use the dns name to connect your clients to clientvpn.
DynamicDNS
KarstenI
As @ww said, this can be done and will typically work. I always go one step further and tell my customers to get a fixed public IP if they want to provide public services where Remote Access VPN is one of them. It will just avoid any future problems.
SardarAlam
Thank you, But i still didn't get answer as i am trying with normal connection, because my employer is not allowing me to get a Static Public IP from ISP, As per my employer MX is designed to Bypass Static IP, while i research so the ISP offering VPN service with Static IP, is it possible to configure Client VPN and bypass Static IP, if ISP block VPN service on normal connection, Please cehck below SS of ISP.and conclude a Final, answer Please. Yes or No.
ThankS.
KarstenI
This is already answered, it can be done.
SardarAlam
Even ISP not allowing?. because ask one of ISP representative over helpline they told me that you cann't use VPN services.
KarstenI
On the screenshot it seems that it is a documented feature of your ISP connection.
