Meraki VPN to Non-Meraki VPN (Cisco ASA)
Holli69
Hi all,
is it possible to build a VPN tunnel using IKEv2 from Meraki MX100 with FW 15.44/16.12 to a Cisco ASA 5516-X FW 9.12 ?
What about the remote-ID, mandatory or optional ?
Should NAT-Traversal (NAT-T) also be enabled on ASA if I wish to use it on MX100 ?
regards
Roland
2 REPLIES 2
Inderdeep
Re: Meraki VPN to Non-Meraki VPN (Cisco ASA)
@Holli69 : Check this out
https://documentation.meraki.com/MX/Site-to-site_VPN/MX_to_Cisco_ASA_Site-to-site_VPN_Setup
Regards
Inderdeep Singh
www.thenetworkdna.com ( Awarded by Cisco IT Blogs award 2020)
Yes.
The remote ID should be the public IP address of the remote ASA.
Leave NAT-T enabled.
Note that you can usually only have a SINGLE subnet in the source and destination encryption domains.  If you include two then only one tends to work at a time.
