Meraki Upgrade
knaik99
Meraki Upgrade
In meraki ,if we have out dated version in Meraki device and we do not do upgrade for such device and we are getting warning then after particular time,
will meraki do upgrade of such device in automatic way?
1 Reply 1
Brash
If you do not keep firmware up to date, you will begin to see warnings in the dashboard under 'firmware upgrades'.
Additionally, depending on how old the version is you're running, Meraki will sometimes auto-schedule an upgrade to force you to a higher version. Dashboard administrators will be notified in advance of this via email.
