Meraki Secure Connect + Cloud WAN
AntoineBAK
Hello
Meraki deployment with Secureconnect needs that all the meraki sites be configured as HUB (no spoke available)
Could you confirm this ?
Have you ever deployed Meraki VMx on AWs with cloudWAN + Secureconnect ?
I'm looking for best practices for this part
thanks
You don't really need a VMX anymore with SecureConnect (if you are only using it as an AutoVPN hub).  You can build a VPN directly between Umbrella and an Amazon AWS VPN Gateway.
https://docs.umbrella.com/umbrella-user-guide/docs/cisco-umbrella-data-centers
Otherwise, there is nothing special to it.  Just connect it like any other hub.
https://documentation.meraki.com/CiscoPlusSecureConnect/Cisco__Secure_Connect_Now-_Sites
AntoineBAK
In the following documentation https://documentation.meraki.com/CiscoPlusSecureConnect/Cisco__Secure_Connect_Now-_Sites/Meraki_SD-W...
SD-WAN  Fabric Devices tab
We can see here we can select spoke so i'm a bit confused ?
ShaunB93
Both Hub & Spoke AutoVPN participants are supported to be connected to SecureConnect
Not sure on the CloudWAN question!
