Hello Team,
I am currently configuring a Meraki MX85 to function as a simple router. The setup includes a /30 public IP on the WAN side and a /29 public IP block on the LAN side.
My understanding is that in routed mode, the MX typically performs NAT from the LAN/VLAN side to the WAN IP.
However, in this case, I intend to use the MX85 without NAT. I want to assign a /30 public IP to the WAN1 port and use the /29 public IP block on the LAN side, which will connect to my router and SD-WAN device.
Could you please advise on how to disable NAT on the MX85 in this configuration?
Thank you,
Sateesh Billur
+91 9945789689
Technical Lead, SME for Meraki Networks, Technical Manager
