Meraki Mx85 How to enable NoNat
Mytestcase
Hello Team,
I am currently configuring a Meraki MX85 to function as a simple router. The setup includes a /30 public IP on the WAN side and a /29 public IP block on the LAN side.
My understanding is that in routed mode, the MX typically performs NAT from the LAN/VLAN side to the WAN IP.
However, in this case, I intend to use the MX85 without NAT. I want to assign a /30 public IP to the WAN1 port and use the /29 public IP block on the LAN side, which will connect to my router and SD-WAN device.
Could you please advise on how to disable NAT on the MX85 in this configuration?
Thank you,
Sateesh Billur
+91 9945789689
Technical Lead, SME for Meraki Networks, Technical Manager
5 Replies 5
RaphaelL
Organization -> Early Access :
Or Contact Support
Take a look at this.
https://documentation.meraki.com/MX/Networks_and_Routing/NAT_Exceptions-No_NAT_on_MX_Security_Applia...
Being a /29 - I think a better solution is a little trick where you create a 1:1 NAT for the public IP addresses, where you use the public IP address as both the source and destination.
Below is an example I have configured.
I prefer this approach because it works with all Meraki features, while NO-NAT mode disables certain things (like AnyConnect).
Mytestcase
Hi Phillip, I will check this option and update you or here. Thanks for the information.
GIdenJoe
Hehe, I wasn't aware you could perform an "identity NAT" on MX'es.  Nice to know!
