Meraki MX105 WAN Interface using SFP-1GB-SX
Noffal
I want to deploy Meraki MX105 with SFP-1GB-SX as WAN Interface, is it possible? Because in the datasheet it is only written 2x dedicated 10 Gigabit Ethernet SFP+ and there is no info about SFP-1GB-SX.
Has anyone tried using SFP-1GB-SX on Meraki MX105 WAN Interface?
Thank You in Advance!
We use 1Gb Cisco transceivers in the 10Gb SFP+ ports of MX250s and they work perfectly.
Brash
Yes, as per the SFP compatibility matrix, that SFP is supported with MX105's
SFP and Stacking Accessories - Cisco Meraki
Noffal
Thanks for your confirmation, it should be same with MX105.
Thank You!
