Meraki MX license query
V_007
Hi All,
My Organisation has purchased an Meraki MX 68CW with Secure SD-WAN Plus license. Would this license be enough to bring MX Online and regsiter on Meraki Cloud ? . Can we configure it the same as Mx68 ?
2 Replies 2
The answer for both is yes.
GreenMan
Just be aware that all MXs in the same Dashboard Organization must have the same license level.   If you start with SD-WAN+ then all subsequent MXs will also require SD-WAN+    SD-WAN+ does have some massively useful features though (Smart VPN exclusions, SD-Internet, Insight...), so it's a pretty good choice, if you're using dual Internet links at your site and rely heavily on a mixture of cloud IaaS and SaaS applications.
If you do buy Advanced Security or SD-WAN+ don't forget to enable some of the key provided features;   IDS/IPS, malware protection, content filtering etc.
