Meraki MX -SD-WAN
LeoAri
Meraki MX -SD-WAN
Hello friends, I have an infrastructure with mx with a security license, I need to implement SD-WAN with two VPN hubs and each one will be the backup of the other, each spoke is assigned to a hub and switches in case of failure, I don't know if this It is possible with the enterprise or security license or if the SDWAN license is necessary. If you could provide me with links to similar configurations I would appreciate it.
Greetings
2 Replies 2
Ryan_Miles
Any of the MX license levels will support what you stated. For the full list of features for each license level refer to this doc https://documentation.meraki.com/General_Administration/Licensing/Meraki_MX_Security_and_SD-WAN_Lice...
Ryan / SE - Networking
This is such an expansive question.  It is hard to answer given so little information.
I would recommend contacting a Cisco Meraki partner, and engaging with them around the design.
