Meraki MX - Keep Alive Config
Tony_Ang
Hi Guys,
Does anyone if we could have the feature to set the timeout or keepalive (cisco ios) in Meraki?
Or anyone have this issue?
I have client who is running a report and it got cut off as if just won't come up the reports after 10 minutes.
I call Meraki and again "Make a Wish".
Not sure if this is a known issue or has anyone solve this issue?
My network environment is fully Meraki.
8 Replies 8
What is serving up the report?  HTTP? If so enabled HTTP keepalives on the server.
Tony_Ang
Hi @PhilipDAth
It's some sort of PDF report from the invoicing team over here.
We did enabling the HTTP keep alives on the server + netscaler on the cloud but it's on & off.
Branch with non-Meraki is fine but branch with Meraki didn't work.
DennisSN
Hi
Did you ever find a solution for this? We are facing similar issues....
Tony_Ang
Hi @DennisSN
Meraki still doesn't have this feature nor their support able to assist as well.
I made a wish and still not granted.
Because our application are fully on the cloud, we have firewall & netscaler in front of the cloud hence we did the keepalive configuration in the netscaler since Meraki doesn't have it.
Regards
Tony
Jesper2750
Hi Tony,
We're facing the exact same problem.
Has Meraki said anything about a fix?
DennisSN
Hi
Still no solution for DIY but Meraki Support helped us increase TCP session timeout to 1 hour on all our MX's
Jesper2750
Ah cool!
I'll try to contact Meraki support then.
Tony_Ang
As for today, Meraki still do not have feature to this.
We still tweaking from the netscaler.
