Meraki MX /31
Mosquitar
Meraki MX /31
Hi All,
I cant find an answer to this, but does anyone know if the Meraki MX supports /31 subnets on the WAN uplink interfaces?
Accepted Solutions
Re: Meraki MX /31
6 REPLIES 6
Re: Meraki MX /31
Mosquitar
Re: Meraki MX /31
That's a shame, I will need to use /30s instead.
Thanks for the response Philip
Owen
Re: Meraki MX /31
The release notes for version 14.24 say it is possible. I have not tried it though.
Mosquitar
Re: Meraki MX /31
Hi Owen,
Ahh yes. I will try and test this when I can. Thank you.
  • Added support for assigning a /31 subnet to the MX’s uplink via the local status page. The IP address assigned to the MX must be the higher of the two available IP addresses in the /31 subnet
RobertoBertin
Re: Meraki MX /31
Any luck with /31 mask test on the WAN interface of the MX?
RobertoBertin
Re: Meraki MX /31
I have tried to configure it in an inactive WAN interface through the dashboard (uplink tab) and it accepts it, but haven't yet tried on an active interface. We are using MX version 14.53.
