Hi All,
I cant find an answer to this, but does anyone know if the Meraki MX supports /31 subnets on the WAN uplink interfaces?
Solved! Go to solution.
It does not.
That's a shame, I will need to use /30s instead.
Thanks for the response Philip
Has there been any progress on this in the last 5 years? We just got a new fiber connection installed for one of our clients, and they only provided a /31 static IP block. Any idea if this configuration is now supported?
A low comment says they were able to configure this, but did not test it.
The release notes for version 14.24 say it is possible. I have not tried it though.
Hi Owen,
Ahh yes. I will try and test this when I can. Thank you.
Any luck with /31 mask test on the WAN interface of the MX?
I have tried to configure it in an inactive WAN interface through the dashboard (uplink tab) and it accepts it, but haven't yet tried on an active interface. We are using MX version 14.53.
