We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
Hello Community
Is it possible to configure vlans directly in the GX20 security router or only in switches?
Thank you in advance
Daren
Solved! Go to solution.
Hey @LowCloud,
I'd suggest asking over here: https://community.meraki.com/t5/Meraki-Go-Community/ct-p/go
Though you might get lucky and someone over here will be familiar with Meraki Go. You never know 🙂
Found the exact answer I was looking for.
Thank you
