Meraki Dashboard VPN status are all greyed out
DavidSam
Hello all, The VPN pie chart is greyed out. This is happening for all sites, but when I clicked on the devices, everything looked okay, and the connections were fine. Please refer to the picture. Is it a cosmetic bug? Can I do anything to fix the issue?
MartinLL
Then i would suggest that you open a support ticket or wait a few days to see if it solves itself.
MLL
MartinLL
Not an issue in any of my orgs. Does it persist if you try another browser?
MLL
DavidSam
I tried with Edge too, same issue.
MartinLL
MLL
DavidSam
Hi @MartinLL , the pie chart is green today. I didn't do any troubleshooting and no relevant log was found. thanks for your responses.
