Meraki Client VPN
Anukul_Tiwari
Meraki Client VPN
Hello Team,
A user facing speed issue with the client VPN, when he is connected to the client VPN and doing the speed test his speed is approx. 1 Mbps (download and Upload), and after disconnecting the VPN speed is almost 250+ Mbps (Approx-Download and Upload).
User machine OS is windows 11.
Any suggestions?
Regards
Anukul
I will assume you are using L2TP connection, have you tried disabling the option to use the connection as default gateway?
Anukul_Tiwari
I don't think that will make any difference, though I can try this, but currently all our users are using CMAK in which the gateway option is default selected, but I can create a new profile for user and check this.
Also can it be something related to Window 11 OS or any specific patch, I have noticed that this one of other user was also facing slowness accessing the VPN and resource over VPN  but all issues was resolved after sending a new laptop with windows 10 build OS.
Ben0391
Hi.
We are currently experiencing similar issues with a handful of users.
Do you think it is a Windows-caused problem?
edit....
I have found various threads on this topic in the forum. It seems to be a windows update...
https://community.meraki.com/t5/Security-SD-WAN/Windows-11-Very-Slow-VPN-Connection/m-p/125179#M3114...
BenH8
Multiple users are having issues with VPN speed on the 2 sites that I work with (one I'm the admin and the other is managed by others). I ran basic speed tests with the VPN on and off and using a remote computer. There is a significant slow down when on the VPN. I know 2 of the users are running Windows 11, but not sure of the others. I'm on Windows 10 and no issues.
